suspension
  • Thread starter Thread starter Ragsta
Ragsta
Good evening to all
Are you aware of a 2d program to simulate the movement of a suspension?
I should set the reticular beam and the degrees of freedom, apply springs and finally see if it moves.
I don't care about anything accurate just to see if the suspension works.
thanks in advance
Good morning and thank you for the answers.
I read some previous working model discussion, but the problem is, it's not freeware.
Since I should study the suspension movement in an approximate way, I was not looking for anything so specific.
I've only done it before I can apply a spring now, so I've been running.
In the past I had a very simple program that allowed me to apply the yielding constraints with which I simulated the springs and I could evaluate the movements of each knot.
then on my hard drive it passed magic partition....:36_1_4:
