sw 2014 custom properties linked to another file
  • Thread starter Thread starter pippo_tina
pippo_tina
Good morning to all,
I have a problem, after creating a part without references (and simple: parallelepipedo with 3 holes), I went to change the custom properties and give me this image:PP.webpBecause I want to change them... I tried to erase them, modify them etc. but it doesn't give me access to anything, I don't know how to do it.
the starting model file is that of another 100 and passes pieces made the same way and that they do not trouble.
Do you know how this connection works and how to eliminate it? ?
Thank you very much
that situation makes you when you expose a body on a multibody side by pointing out to keep the properties of the cut-off or those of the file connected.
you can only erase what is not written connected to the parent part
mmmm... interesting. . .
I had never found myself in such a situation.
Thank you so much for the info!
Good morning to all
I apologize for the long absence... but I had detached the plug from the brain in exchange for a couple of weeks in the mountains.. .
Massivonweizen: for notes connected to the father part, once I have already created the derived part (and it would be a mess to do it again), can I do something to stop the link? or do I have to hold it like this?
Please note that I have already made several modifications to the derived part. .
thanks for the courteous attention
greetings and good day to all
I tried to re-execute what you theoretically did, and I think you have to delete all the properties by hand.
when you do the body rescue process, remove the linking check of custom properties.Cattura.webp
the only one I know is right button on the body>elenca external references> interrupt everything
see image imageView attachment 41304
However in this way you will also lose the connection to the solid.. .
I tried... my models not even this solution works. ..probably because it has already written the properties and when blocking the link freezes the last saved.
And of course he loses it.
But unless someone comes with an ad ohc solution, I don't see alternatives.
Hello everyone
Sorry I'm late, with the advice you gave me, I can get out of it perfectly.
Thank you so much, as always you are my red cross
Good weekend
Hello.
A similar problem is presenting me importing a step.
with the 2015 version all ok with 2019 I find the table frozen.
I imported the same .reg configuration file, but the problem persists.
Is there any function to activate/disable?
the sldreg file is a file with customization settings and has nothing to do with importing a step.
What frozen table are you talking about? a step is a neutral file and contains no ownership data or other information but without stioric geometry of functions
I talk about the same table as the 1st message or the table summarizes information that I find confelated or all entries with grey and not white background.
the imported step file with 2015 gives me the possibility to change the entries with the 2019 version instead the same step gives me frozen voices.
the imported file is fine, there must be some setting on the 2019 version to set to be able to work on the table summary information, but I don't find it.
because you have almost certainly activated the 3d interconnect in the import options.
Boh.
possible, in the company we passed from 2015 to 2019 and we are resetting the functions that interest us. in the week they come to give us an update course. Meanwhile Monday I look for where this function you suggested to me and let you know. Thanks for the tip.
