sw2017: Affordable design problem? ? ! !
  • Thread starter Thread starter strudeldemele
strudeldemele
Good morning to all,
I hope you can help me, I'm in a mess....
at the end of the project, mold and, after two days I open the slddrw file of the assieme and freezes, practically in the screen I see the table with all the views, I can zoom, but you do not load the tree and do not do any other operation;
while from task managers the program works between 20% and 65% with cpu
do you know if you can recover the file? ?
thanks in advance
sure it is not a question of too heavy files and that takes a lot of opening time?
have you tried suspending all or part of the aid to verify that the design opens?
....it is finally open after about 45 minutes, I don't know what it had, the only strange thing: all the files that I open cannot save them because it tells me are in use by "admin", but none of the 2 users who opened it are not "admin" but "signer".
I also tried to do as you said (suspend components) but did not open.
in any case the pcs are more than good for the software, usually open assemblies and designs ten times more complex and with more particular mooolti.
boh, if anyone comes up with something, let me know.... for now I thank you for the very kind collaboration
I don't know if the model contains external references to the folder where you are working as library parts for example. try to make a pack&go and see if the problem remains, otherwise try to make a physical copy of the workbook, copy windows and then open the drawing in the new folder. If you have external references to the folder try to open and reset the template by telling them where to go to read the files... .
