cacciatorino
The cad crashes at least a couple of times every half day at work, is it normal? machine is a precision m laptop with picture board.
swx 2010 sp 5.0
swx 2010 sp 5.0
I'd say it's not normal. in what situations crashes?The cad crashes at least a couple of times every half day at work, is it normal? machine is a precision m laptop with picture board.
swx 2010 sp 5.0
Usually in the table environment, when I lay with the odds, I try to be more careful to see what causes the discomfort.I'd say it's not normal. in what situations crashes?
Could you make it clear that I'm not very clear?actually could be such a problem. you can also export the entire solidworks folder to hkeycurrentuser-> software and then stationary. If the problem disappears it means that there is something in the logs, if it stays you can restore the settings from the exported file.
where would you find this folder?
so if I realized by doing the "try" to delete (doing a security copy) of this folder you can see if there is something that breaks the boxes to the program.. .nei registri di sistema->hkey_current_user->software->solidworks
