Calender
Good evening,
I often find myself creating multiple different codes of assemblies consisting of the same components, to be able to insert them as right-left assembly in another set of higher order (in practice it is to make a speculation of a subsieme in a set, without using the "specchia" function, creating instead two different subaxes that contain the same ipt files and therefore do a double job). the components of such assemblies are assembled differently depending on where they are placed, but the ipt files that make up them are exactly the same. Is there any way to "configure" a set? I would be tempted to use the representations and suppress components according to the need for right or left mounting, but I do not think it is the right way and the levels of detail have always bothered me. Is there any ad hoc method?
