symmetry
  • Thread starter Thread starter panormus
panormus
Hey, guys.
I'm designing a wooden workbench and I'm making the two left legs with the two crosses making the first leg and the second as a copy of the first. now the need to make breaks on both legs but symmetrically. if I make a first run with the "tasca" on the first bodypart it automatically generates on the second one a pocket (interesting and comfortable), but not in a symmetric way as I would like.
If I work on the second leg by applying a symmetry, in addition to changing the first bodypart, which should be firm, I create a bodypart that is the union of the symmetrical part :eek: (nice, new term, all rights :biggrin:) and symmetrical.
I don't know if it's clear. I hope so. Can you give me some tips?
Say hi.
In fact, it's very clear, but I'm gonna ask you a question: Why did you use different leotards for such a simple object?
Greeting! ! !
of the noble
Greeting! ! !
of the noble
because what I know is the result of a slow discovery.
What is not clear?
I have to work on an object and automatically you have to replicate on the second symmetrically; That's all.
What is not clear?
I don't know if I understand...
but I think you have to create a catpart "a" then make a copy with connection and save it as a catpart "b". on the catpart "b" executes the mirror.
Now. all changes you will make on catpart "a" will be transmitted to catpart "b" , but speculate
much more simply the problem you can face in two ways:
work at part level (gamba part.jpg)
shape the leg
creates a symmetry plan
you create the mirror
wanting to add a workmanship stands as "object in work" prisma.1, you make the changes and then puts "object in work" partbody.
automatically the processing will mirror.
This method contemplates a part composed of the object and its mirror.
product level work
you create a set composed of table and leg
binds the leg
a symmetry of the leg(gamba product)
or
binds a second leg in the correct position symmetrically (leg together)
in all these cases making a change to the leg it will be repeated on the other components
Mar
shape the leg
product level work
binds the leg
or
Mar
the first for me seemed more complex (considered that I recently installed the sw), the first most feasible but .. I always have problems:
1-cree a symmetry plan
2-selections the 3 parts that make up the first leg (a1,b1 and c1)
3-apply the symmetry, but it moves to and only to the longest leg with the dig (see print screen) when I would like an exact copy of the first group called a2,b2 and c2.
What am I wrong with you?
you can not make a symmetry of 3 parts simultaneously
do 3 symmetries compared to the same level of the three parts
or
do a subaxieme a1 b1 c1 and then do a single subaxieme symmetry
Mar
