synchronization work on parts
  • Thread starter Thread starter lillo5
lillo5
Good morning
I have this problem:
- 2 part within a product
- I use a hole on the part1 as a reference to drill part2 (concilitation case when placing it)
- if I move the hole on the part1 I don't move the one on the part2
Where am I wrong?
in the logical tree the symbol of part 2 should be changed > 2 toothed wheels with blue chain.
If you don't have that means there's no connection (context) between the parts.
to review the methodology or settings
I made a try simplifying the speech with this result1572872160052.webpwhat should I change to get the desired result?
I think I found the solution.
putting the check "keep the connection with the selected object" seems to work
in fact you have to work in context.
Look at the symbol in the logical tree.
if everything is correct, you will have another symbol representing the link (context)
In fact now I have this symbol next to part2.
Is it better to pop up in that window for external references or just those 3?
I don't know if you use public items > might help you ...
I don't know if you want confirmation when you select external references...
ps: working in context is very practical but you have to be very careful what you do, selections etc.
If you are not the only one working on the same project, you must define the guidelines but above all respect them :-)
