tabella fori - drilling hole table
  • Thread starter Thread starter Staedtlerp
Staedtlerp
Good morning to all,
I have a pretty annoying problem. ..I would like to create the detailed holes table of a perforated plate. I am trying to use the "creates a drilling hole table" command instead of "hole size table" so that I have a more detailed description of the holes (hole depth, thread etc.). I can't make this command work:confused: i.e. I click on, the parameter selection window appears to me, but if after clicking ok nothing happens...what is wrong??? ? ? :confused:
I do not know (and I do not have) the form in question.
on the net if you interrupt:
Create a drilling hole table catia
a link to doc free catia
I hope it's useful
the procedure is this:
1) Select all holes
2) Select the command table holes
3) selection of absolute point 0
4) opens the tab where you will go to sample the parameters of the table.
ps. Pay attention to this command from as reference only the diameter of the hole and the distance according to the xy axes from point 0. is not indicated if the hole is threaded or not and the depth at least from the test made the result is this... I expect those who have more than me to give a more thorough delucitation. . .
first of all thanks to both:wink:
As for the answer of gianni55 I have already tried to look for it myself on goggle and I too found the guide on catia doc free.... the poroblema is that I just can't get the drilling hole table :confused:
regarding the answer of joshua 662 the command you indicate to me is the standard one of the holes that works but that unlike the command created to drilling hole table does not allow me to set the parameters to display
(depth, thread etc...)
in any case, to scan of misunderstandings, the command I would like to use but I can't is that in the image attached below:finger:
immagine.webpthanks again for the answer
View attachment 47406thanks again for the answer
I don't have that license in my office, a friend of mine has a cnc machine company maybe he has that license, I ask him if he can do a test and I'll get the procedure... .
thank you very much for the availability joshua662 :biggrin: I wait then your answer:finger:
