table 2d: no selection of part of view edges
  • Thread starter Thread starter czar
czar
hi, swx 2021 sp 1 64 bit, but little matter for years I have problems of this type: in the table setting of assemblies it is not allowed to select the edges outside of a "hypothetic" graphic window, then impossible to quota put aces etc.
These are assemblies built with under assemblies and display states where to a machine are coupled x accessories managed with display states (not with configurations, which are still present but to manage other variants, in order to limit the number of objects present in the axieme that otherwise generate an impossible matrix to maintain).
often the problem is solved by turning off the pc and restarting, other times opening the 3d and selecting the correct configuration and display status, in other cases waiting a few minutes without doing anything. Then there are cases where there is no way.
Am I the only one?
precision workstation 3630, ntel(r) xeon(r) and-2274g cpu @ 4.00ghz 4.01 ghz, 32 gb ram, nvidia picture p2200 (but I repeat, it also happened with old releases and old ws)
