table and scale
  • Thread starter Thread starter pietro2014
pietro2014
Good morning to all,
When I make tables with details that will then be cut, I am forced to make single tables or in any case tables where I can insert the details in scale 1:1 otherwise the supplier would be forced to scale all the details.
in autocad there is the paper space to ovviare .
Is there someone who solved it differently?
just that the first view inserted and the flat model have the same scale, I did so and eugenesis explained it at the end of this discussion: then over time I saw that exporting the dxf of the flat model is safer, sometimes we ran away the "death" because I forgot to check that the scales of the first sight and the flat model coincided
right, they're dead to me, too.
I recommend this free app that allows you to export dxf of flat models contained in a set.
I carry directly the dxf from the flat model from the ipt not from the design!
the problem arises when sending a supplier the dwg file of the sheet. if in the drawing you have different stairs between the views of the drawing and the view of the development, who extrapolates the flat model by cleaning your dwg file is a slaughterhouse. the app you want to do just what you say, opens every single sheet contained in a set, even if nested, and extrapolates the flat model from the 3d model
I only use dxf for interchanged files with the lamierists, at least I'm not banging with the scale of the views, so much to them nothing changes. Now who has the new cnc bending machines wants the step directly, at least even the menata of the factor k is resolved, unfortunately for now I have only one customer so:cry:
question, do you send him the step of the folded and undeveloped piece?
Yes, the folded sheet, finished, saved in step. their software develops I take into account the beams of fold, thickness and material and generates the k factor suitable for their machines.
Thank you!
by curiosity, you know what machine/software they use?
