table and special section inventor 2011
  • Thread starter Thread starter SeriousTony
SeriousTony
First of all, save everyone.
At work I find myself having to put on the table some details to quote.
I wanted to ask how it is possible to put into the table a piece already dissected, that is without having to put the view "not dissected".
I thank everyone in advance;)
the views need and it is not possible to derive views "fantasm". Just keep the views you don't need outside the cart. However it assesses well if it is really the case of not having full view + section. If you put the example we can evaluate it together.
okok understood... I on the view in section I have a flange and a tree welded among themselves...the tree I leave it whole excluding it from the section... of this view I should show the section of the tree where there is the stick. But I can't... can't I? I hope I explained.
If the tree and flange are welded among themselves, I deduce that the tongue seat is at the end of the tree (not engaged in coupling). you need to make a partial section and there is the instrument in inventor.
I would like to see it in view while keeping the above criteria. I thank you immensely for your availability and clarity;)
classical visualization is done with dcb, while the correct one as you want to do you do with de. I attach practical directions.
ps: also in the second indication I recommend to add a partial or projected view to see the shape of the seat (asola)
Just what I was looking for! You made me clear the doubts of a day in 5 minutes! ;) thank you again;
