table creation to appear by selecting a block
  • Thread starter Thread starter New Rider
New Rider
Good evening to you all,
I wanted to ask, if possible, the procedure in order to make a table appear as soon as you pass over to a hypothetical autocad block.
I'll explain. I would have to put some extinguishing on the planes. so once you create the ''extinguisher' block, I go to place it at my liking in the planimetry. At this point, once the extinguishings were placed, passing over with the mouse (ex. hyperlink) I would need a tabellina (inland with autocad type ''caratteristica linea'') to appear to me where I would go to insert that I know a historian of that extinguisher rather than its characteristics.
Thank you very much for your cooperation.
you can connect your autocad design with a db access via the dbconnect command, having previously configured the link model with dbconfigure; with the fast properties then the tabellina would appear. to check if you can also customize with the fields of the link model.
Otherwise you could use block attributes but I don't know if it would satisfy your request.
thanks for the attention.
let's say immediately that with the blocking attributes I can make a maximum description of my block. of the type extinguisher powder 6 kg or extinguisher co2 5kg. to me however would need a detailed description of the type extinotor xxx serial xxx xx year quickly and automatically without creating a excel collagement for each block.
So I have to study the db access I don't know what it is.
Sorry guys, but I can't finish what I wanted....
would anyone have any ideas/possibilities?
because attributes don't satisfy you. . .
you could write a self-lisp program that 'links' the info you want through xdata (extended data) to the block.
there will then be a command to insert them into the block and a command to reread them in a window built according to your requirements with the dcl language.
of course to read the info you will have to invoke your command and select the block.
