table distinct materials
  • Thread starter Thread starter Marve76
Marve76
Hey, guys.
I have some doubt about it.
I have a set consisting of about 97 parts, including bolts for locking.. .
I have to create a separate piece of this together and then print it, but I have a problem that I can solve.
I put on cartiglio the distinct that then I go to bubble, but
when I go to insert the table, I find everything, even what I did not stamp and when I go to print it there are item numbers not present in the bubble. .
how do I display only what I go to bubble?
but apart from this, according to you is the correct way to create a separate code?
Of course, it's clear, but it's okay.
I put on cartiglio the distinct that then I go to bubble, but when I go to insert the table,
first insert the distinct then boil then insert the table? table of what? if you always talk about the distinct always use the same term otherwise you create confusion
case never is the bubble that is deficit because it is this that follows the distinct not vice versa.
If you didn't insert all the bubbles corresponding to the distinct seems normal to me.
If you have 97 items, then numbers from 1 to 97, the bubbles will have to be from 1 to 97.
I think you can't use a separate cut, which needs to be prepared well before and will have to be auto-rolled without ever putting hands on the screen, you lose the links between the data
The correct procedure is:
insert the ashem
insert the distinct materials
insert bubbles
to verify if the bubbles of all pieces have been inserted go to the right of the separate materials and click on the arrow appears to us so as to temporarily expand; you will see the hierarchy of components (axieme or part) and what has been stamped. as always See guide
Mah, I think I understand the problem. You practically don't want to bubble all 97 components, do you?
if it is so you should move the components to the distinct bottom (you bring them to the bottom of the distinct). so if you want to bubble only the first 50 components, go to bring up in the distinct 50 components, in the drawing boils them and the remaining components in separate you go to hide them.
you may select "excluding separate materials" components that you do not want are considered in the bubble and table
I hook up with this discussion about the bubble solidworks;
I use sw 2017 and I need to bubble in a multi-level set, all parts.
I have inserted the material table (all parts), but the bubbles do not come out all but only those related to the sublevel (as if I used the first level material table);
How do I brand everything?
Thank you so much!
is a description that explains little about the problem, if you show us the property manager of separate settings maybe you can understand something. at least to start giving an address to ideas
OK, here are the table settings:pippo.webpI have a set with other sub-assistances below.
I need to have a table of all parts with the bubble of the same.
check that in the subaxial configuration the distinct properties are set as an exhibition
Yes I have checked now;
the problem is that in the table materials I get out all the bubbles of all parts (of all the assemblies).
So the tabellina is correct and I'm fine.
when I go to bubble, I don't bubble all numbers, but only a few (6 out of 95...); I don't understand why.
then it's a little different than what you understand from your first post.
it is difficult to stable without file, put at least some picture of the drawing that you try to deduce the problematic.
You are right:
However, I managed to find the solution;
on the drawing, clicking on the view together with the right, I selected the separate table materials I wanted (from the curtain, see image); in this way the automatic bubble follows the numbering/list of the selected set.
I attach image.
I add a question.
is there an automatic method to understand which parts have not been branded?
sw bubble in automatic only the components in sight.
How do I know what didn't bubble?
Do I have to do this manually?
in the distinct materials, not in the cutting one, on the left there is an arrow that expands the distinct showing file type (part or together) and whether or not boiled
Thank you. you do not know how much time I will save in this job of manual preparation!
Thank you! ! !
