table excel in drawing board
  • Thread starter Thread starter AK-47
AK-47
Good morning to all,
I wanted to know if there is the possibility of, once a table excel is inserted in the drawing board, link the values between the table excel and the table of proes.
In practice I am interested in using the parameters I use in the proe table to perform operations (type differences between volume of parts etc.).
I have seen that you can export the proe table in .csv format, but (aprendola then in excel) besides putting all the parameters on the same line, I don't know if it remains connected to the proe values (for example if I vary a volume, it updates automatically as the drawing proe table? ).
thanks and good work
the answer is no, the data does not remain dynamically linked to excel.
this for a reason of lightness of the models and stability of the program.
you can with pro/program (which is part of aax) update the data but, the connection remains static.
thanks maxopus,
but operations like excel (simple as additions or subtracts) directly in the proes tables are not possible?
or in family table tables? it was a comfortable thing that I used in solidworks often. I was hoping there was some trick in proe.
In essence the data that generates me pros on the calculation of volumes remain static on the table and can not use them in any way?
within the pro/e table you can use normal arithmetic operators and not only and tables are dynamic.
data instead of loads from an external excel table are static.
Meanwhile thank you for the answer,
but how would I do operations between the various parameters? I insert the table with the various parameters style "repeat region" (type for example &asm.mbr.pro_mp_volume).
how to make the difference between two volumes of 2 parts?
and between parts of different assemblies?
