table excel inserted as an ole object is not completely visible
  • Thread starter Thread starter Lau ra
Lau ra
hi, I have inserted an ole object, a excel file on autocad 2008 and yet it does not display all the content, it cuts me the table, I tried to enlarge the object by autocad but nothing changes.
Can someone tell me how to do this?
select in excel the fields that interest you and make a copy. in autocad do a "special glue" (incollaspec). insertion will always be as an ole object. You're not gonna cut it.
or the other solution is that with the table command in creating a data connection, in this case you will not have an ole object.
