Aurora_86
Good evening to all,
I have a design consisting of a large number of points I have to extract a table indicating the coordinates of the same. to do this I found a method that however seems too long given the large number of points present in the drawing. the steps of the method are:
1_ next to each point insert an attribute (1,2,3,etc)
2_ make a block for each point-attributed couple
3_ command extinguished and extract the tabellina
However the second step of this process makes me waste too much time so I ask you if you know a faster method to do as described.
