table extraction with coordinate points
  • Thread starter Thread starter Aurora_86
Aurora_86
Good evening to all,
I have a design consisting of a large number of points I have to extract a table indicating the coordinates of the same. to do this I found a method that however seems too long given the large number of points present in the drawing. the steps of the method are:
1_ next to each point insert an attribute (1,2,3,etc)
2_ make a block for each point-attributed couple
3_ command extinguished and extract the tabellina
However the second step of this process makes me waste too much time so I ask you if you know a faster method to do as described.
you only need point 3: "command Extinguished and I extract the tabellina "
between the properties to export points select:
- x position
- location y
- z position
hi dieva, if I only use point 3 as you suggested I can not associate to a terna of x,y,z coordinates a specific point.
I would like to get a tabbella made in qst way:
point 1:x,y,z
point 2: x,y,z
point 3: x,y,z
I understand now. surely on the web there is some free program that replaces the points of the blocks.
you can do cominque also with the program coordinate (freeware) here:http://www.domenicoieva.com/coordinate.htmlthe program inserts a booster auto text on each vertex/object that selects.
insert a text by removing the check mark from caselle x,y, e z. and putting as value of offset x e offset y (in this way the text ends at the same point of the point).
at this point you can use the command extinguished by selecting only the test , the fields to be exported will be content, position x, position y and position z.
in content there will be the num. of the point.
