table "flattened"
  • Thread starter Thread starter Pampi
Pampi
Good morning to all,
for the first time an anomaly happens on solidworks 2016, and I can't solve it: after having modeled a part in sheet metal start putting into the table. when I try to introduce the "flattened view", in its place there is another.
Has anyone happened yet? How does it work?
Thank you in advance.
I apologize for wrong "forum", I messed up by sending the message.
I'll send you the files anyway, if you can see... .
having 2014 I can open the file only with edrawing so I have no way to see the flattened view since in the design is not present.
About the design if you're not the owner of the studio I'd be in you I would delete the paper and all sensitive information
thanks anyway for the interest and excuse again for the error on the forum.
Have a good day.
practically you have to go into the part, put the default development configuration, and activate the flattened function. then return to the default and save configuration.
Thank you very much, I immediately try. So you're not......... ...sobad.
Thanks again and good work.
positive test, everything solved. Thanks again.
