table holes advanced...again!! !
  • Thread starter Thread starter Staedtlerp
Staedtlerp
hello to all and wishes to all,
I write to you because I came across again in the same yearly issue of the advanced cylindrical hole table v5. I had already had this problem long ago and in this regard I had already opened a thread but without solution. I had then renounced and arranged by quoting each hole and not using the command. But now I can no longer "resolve" in the same way but I must somehow succeed in using this famous advanced hole table (I attach a photo of the icon)immagine.webp. the problem is always the same: Click on the icon, an editable menu appears where I can select the characteristics to indicate (filettatura etc.), click ok but nothing happens. I also gave a bow to the file catia.doc http://catiadoc.free.fr/online/mtdug_c2/mtdugbt0701.htm following all the steps (especially what tells me to add the 'technological results in the contextual menu of the body containing the holes') but without being able to solve it.
I know it's repetitive, but does any of you have any tips to give me or do you know how to run this command?
thank you very much to all:redface:
I think you should create the part as the example I attach (and on which it works, but don't ask me how it is done, I took it from the guide)
Let me know.
Hi, gianni55.
Sorry the delay in the answer but I was at a client for a few weeks and I didn't have a chance to verify:biggrin:
I downloaded the attachment and tried to make the table using the command and it works perfectly:finger:...and the problem is just this...how does it work? What am I wrong with the construction of my plate? ?
I created my plate as a solid and then through the hole command I created all the holes I needed. I subsequently assigned them the technological results (as specified in the guide) but nothing!:confused:
I saw that some of your holes were created through boolean... why? ?
Thank you very much
I suggest that the example taken by the guide, is made with a special module (for moulds?) where the holes are made by subtraction using objects of a particular library that contain the technological results correct for the compilation of the table. Perhaps in adding them to the hole, do not use the correct procedure or syntax is wrong.
try looking for this library and figure out how it is made.. .
is a hypothesis.. .
