table of a sheet contained in part multibody
  • Thread starter Thread starter Gennaro3D
Gennaro3D
the topic has been treated earlier but regarding me not completely, so I do this post if someone can help me.
The question is: if I have only a folded sheet to put on the table I have no problems, I choose normal view and flat view to have development.
the problem is when, I have a multibody part that contains a folded sheet and I want to insert in the table also the view of the flat plate to have the quotated development ... for the moment I "resolved" doing a body save creating a part only of the sheet and placing it on the table (at this point I have the flattened view) as a component, but this has earned me the usual public smerdata by Dr. to which it does not seem true every time to invere against solow. Can anyone tell me if there's a better method?
when you enter the view choose, in the property manager, select bodies, is bypassed to the part where you choose the sheet and give confirmation; at this point you are reported in drawing environment and if you have done things correctly you will find among the available views that flattened
Thank you for the answer, but I obviously did not do things properly, because it does not work.
I select bodies and in the view I find only the sheet (the selected body) but in the views available on the table , together with front , superior etc., there is no flattened view , while when I make a part with only the sheet si, also the flattened view appears ...
ps stop all ... I saw a flat repeat box in the property manager, just a moment before crashing ... reboot and maybe I solved ...
