table of imported components
  • Thread starter Thread starter Biggmetals
Biggmetals
Good morning to all,
our collaborator has provided us with pomols shaped on rihno,
my problem is: after importing them on solidwork (created the axieme that I need with our components and blablabla) in design environment are not displayed well all lines.
I have already tried with all methods of display, as well as to activate tangent edges. but the lines that are not displayed, do not want to know to be seen in the table. In fact, I can't even select all rows from the solid, if not the ones you see in the screen (to be exactly precise I miss all)
Immagine.webpmy question is: is there no way to correctly see the imported component if not with the shady display style? (if you use shaded with edges the lines would still be incomplete as you can see in the screen)
Thank you very much :)
missing the image
is it an element made by surfaces?
I did not import all files (in archive most of these components were already solidwork files with a single function "imported1")
I still think so, in diagnostic imports the symbol is that of the surfaces.
for information purposes this conclusion has been reached:
you want for some "wrong" setting during export;
you want that for some "wrong" setting during import;
you can't solve the problem or you can't come to the end if you don't: by recreating the part from scratch.
I still thank massive for the availability and in case someone ever manages to come to the head/resolve somehow sayaaaa (because of files so I have to bizzeffe)
peace
