makeng
Hello, everyone. I have sought a solution for a trivial problem but, as often happens, what in different environments is trivial in the cad is a cyclopical enterprise! the problem is:
how do I insert in a design a parameter that is the sum of all equal parameters that are associated with each part in the axieme? We suppose, for example, that within a set I have 50 parts all with a calculated and different length parameter for each part. I would like to have the sum of the parameters of the axieme. For example, I could use the total length of profiles used in a frame. or the total surface of the plates in the axieme....in excel is soon done: I put in a box a sum formula(a2....) and is solved. but in proe?
