table revisions commanded by pdm
MARCOC
hello to all, I have seen that since 2018 on the solidworks pdm have added the function to manage the audition board, someone uses it? Can you make it work? I have seen some official videos of solids and others taken on the net and although little clear it seems to work, it remains in fact that I can't let it go1639638311016.webp2 problems, it does not update the numbers in the triangle, and even if imposed 5 lines visible from solidpdm, it always shows me and only 1 revision, in the example above I should see row one 01 and then the line you see
Thank you very much
