table series with reports
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning.
I'm trying to create a series table with relationships instead of the desired distance in the exel file
I noticed that the series updates partially so I suppose there's something he doesn't like
Am I wrong in something or am I doing something that cad does not support?
thanks for the support
But where exactly would you write these reports? in the table cells that opens you when you do series table or have a separate excel file that matters to you?
hello calacc I tried in both ways but nothing that you do not understand who commands... .
Good morning.
good evening, that I know the hole table provides a set of coordinates specifically written in the excel file, I therefore believe that the partial interpretation of the given in table is given by the interpretation of the formulas by creo.
Let us put it so, you have a first excel with the relationships that calculates the coordinates, link it to a second that will therefore have only the numerical results of these relationships, only the second the amounts in I create that therefore will not have the problem of this
partial interpretation of the data
Could you fix it?
ciao shotfreeCan you clarify?
ciao @daniele-san , the problem could be the formulas present in the excel sheet that feeds to creo, it seemed to me to understand that your sheet performs a series of calculations, from whose results comes the numerical data exploited by creo to locate the hole. I believe that the calculations in the sheet may be misinterpreted by the cad, a test you could do is insert a table with dry data (like a copy, special paste --> values), so you should not have the problem anymore.
It's what I did, but with the reports I had a way to do some mods without being able to recheck the whole series.
Of course, I understand it perfectly, however, you must keep in mind that the file you open and visualize in excel represents a support; I create you interface for the passage of data, but it does not work with the formulas of the spreadsheets. For example, if you look at the .hol file (by way of example), you can notice that it is nothing but a table completely similar to a .csv file, the data deriving from the hole table is interpreted (even if you open it in excel for compilation).
happy you have solved ;-)
