table sizes bolts and inserts
Alessandro 02
Good morning, I just approached the world of mechanics, and I was beginning to design bolt nuts and a steel cassone. I wanted to ask if there was a table with the measurements to draw the inserts and bolts. I want to design everything alone as much as possible.
Thank you very much.
nuts and screws are bought by trade.
bolt = nut + screw.
nuts and screws are standardized to catalog.
search. Google knows.
If you have a different problem, explain yourself better.
a This link a standard bolt catalog.
design also means calculating according to regulations the efforts in play, deformations and push-ups.
One step at a time.
bolt = nut + screw.
I rewarded the definition of bolt, not to be confused with the Chinese definition, which could be: "The bolt is a plofondo ballad."
maybe by inserts you mean rivets and similar.... like these1714849993856.webpthere are catalogues where to take measures.
with solidworks you can try to manage them as a single part or incorporate them into the multibody part.
then there are different levels of modeling and management.
for me the dumpsters are these...1714850207171.webpfor the Romagna cassoni are these1714850253665.webpWhat do you mean?
if you want a hand you have to put patterns, photos, details etc.
