TECNOMODEL
some questions about the management of styles that still remains a little dark for me:
First of all, my need is to have 2 types of table, drawing and working cycle, in which basically only the dimensions of texts, quotas, symbols etc. change.
I then created my 2 templates with relative squares and cartilage and so far everything ok.
I already have a norm that I apply to the table setting template in which all the styles I need are contained.
I mostly apply the default iso appropriately modified where necessary.
in the cycle template I created the new norm, changing some text sizes, quotas etc.
to do this I created new text style,size geometry pane etc.
I then selected the latter in the default values of the object, saved the whole and saved the norm in the style library.
It works as I wanted.
now the problem arises: I make a table with the template of the same and here the standard created for the working cycle do not see it, in addition to the default values of the object are set the modified and selected styles for the cycle.
What's wrong?
Thank you for your help.
What's wrong?
