Table update problem
  • Thread starter Thread starter sanvito davide
sanvito davide
Good morning,
I had to open a table yesterday afternoon to make a change.
the various views of the table continued to update, strangely allowed me to work on it (various quotas or notes ) but did not allow me to export it in pdf , as it required before the update of the views (I left it open all afternoon but did not update).
I tried then to open it with my colleague's computer (as we have a shared server with inside the drawings), but it gave me a mistake on the table and did not show me the views.
This morning I tried to make a new table, but the result has not changed... the newly created views continue to update continuously.
You know what the problem can be and how I can solve it.
I take advantage of you eugenesis, can you explain the difference between raster and normal views?
the "normal" are calculated definitively, the "raster" are like images, a little + ugli and limited but + fast
to say it in short
are seen normal .. are seen created with the command "basic view " when making the table
to say it in short
are seen normal .. are seen created with the command "basic view" when making the table ...any suggestion?
Is there no way in which these views were created, if you change sight, is the raster check flaked?
