tabled with stock quotas
  • Thread starter Thread starter RDM72
RDM72
Good morning to all
I have a problem not new, but I don't remember how I solved it:frown:
and maybe I found the solution here, but I can't find anything about it:frown::frown:
I put on the table a set made by me that I built around an imported set
in the orientation of the view I choose the face of my base (which is slightly inclined compared to high, as you will take the plans of the imported axieme)
I put quotas, even between the parts I drew
some turn right and others bend or crush me, others just don't put them
Surely it is a problem of plans to revolve but it has already made me miss half day:
Is there anyone who can help me?
I forgot I was using inv2013
Good morning to all
I didn't understand 100% of what you're asking, but maybe I guessed your problem. .
try using the "view face" command. . orienti the axieme according to the face you care more, then impose the current view as "home". when you put the axieme on the table, the views should be oriented according to the faces you just set. .
hero I had already tried to update the home view with the top on a plane of my interest, but when I put on the table I will hang of the setting:frown:, and this could be the basis of the problem
maurom I followed the link of the old discussion and solved
Thank you very much!:finger:
try this way:
- dx button on the view
- type of generic quote
- put the flag on projected (if it is on true you should make the odds out. . )
Let me know!
try this way:
Let me know!
thanks, but I had already solved following the link of maurom
