tables - links between files
  • Thread starter Thread starter agi85
agi85
I can't understand if I can create relationships with sw tables
between different parts.. For example if I change a length in one part I would like it to automatically adapt another dimension to another. .
Is it possible?
If yes... who explains it to me? :p
Thank you in advance! ;
Yes, you can do... and you explain it:
However it does not concern solidworks but excel.. .
Is it possible?
Hi, the explanation is a little vague, I realized you have to tie two parts, but how? Are they part of the same together?
Is it possible?
I think there are more ways to tie odds between them, with an excel table that you can insert in the file you can set (but on youtube as well as being clearer you can see step by step), if you can use equations and tie the odds between them with simple formulas. (if I understand what you have to do).
do you have the youtube address by chance ivan?
Can you give me an example of equation?
I believe you understood:
cmq yes, parts that will then be in the same together. .
... ah ah ah, if you want to do it on the disk c:\ maybe I could help you, but if you want it to work on the net, leave every hope, personally I try from 2009 and right now I have not found anyone able to do it (truly, not in theory), not even the assistance or swx itself .... :frown:
... the only hope was maybe just soliduser :rolleyes:
...but on youtube as well as being clearer you can see step by step.. .
...well? and what are you waiting to shoot us the link of yt???? ? :wink:
you may be interested or helpful to these topics:excel2007 to command assemblies and parts: from c:\ yes, on net no... (? ? )come comunicae tra excel e solidworksconnect 2 sketches of 2 different parts siolidworksequation: tree length.prt=length tube.prt+50a nice yt tutorial of soliduser in this regard (... at great request :d)
[Happy Christmas!!! :]
first a good year to all.
I apologize you never told me if what I suggested in the above discussion works, go see the last answer to your post..
