tabs and grooves
  • Thread starter Thread starter sangkavr
sangkavr
Hello, girl.
I am new in the forum,
I've always used solidworks so far, so I'm not doing well yet.
in solid inside the axieme it is possible to select tab/scanalatura to couple two parts creating the two features on the two parts,
It is something that I cannot find in pro/e,
Tell me if you can do it is what?
Hello grz.
I answer you again because I often deal with plastic objects to mate like what you put in the other discussion
to make a tab/scanalization (i.e. if I did not misunderstand a female male tooth that facilitates the coupling of the two pieces) I usually build it on one side making a cut with sweep and on the other making a protrusion with sweep
the command is always the same (sweep) you must first select the trajectory along which it develops and then draw the sketch that realizes in one case the cut and in the other the protrusion
you can look in the guide some examples looking for this command
N
that I know there is no command that realizes it automatically at least in the wf2
In fact I had already thought about it, but I was rooted in the search for the function.
Thanks again.
and if once you create a groove or function, you will save it as udf and go call it back whenever you need it?
p-h
I'll see them all.
but x now as I have fried I follow the traditional method :-d
to learn it takes time, as soon as they leave me free:-d
of the last video there are two things I don't understand, provided we use the wf4.
  • when it passes at the beginning over to a part you see the preview, what utility is it?
  • when opens the area from which you choose the udf also what application is?
:36_1_1:
