gioedofabri Guest Mar 30, 2015 #1 Good evening, I need help, how can I create a 30 degree tangent surface at this radius (as in the attached image) How can I do that? Thank you. Attachments tangente.webp 19.2 KB · Views: 5
ceschi1959 Guest Mar 30, 2015 #2 gioedofabri said: Good evening, I need help, how can I create a 30 degree tangent surface at this radius (as in the attached image) How can I do that? Thank you. Click to expand... first is welcome presentation. according to your question does not make much sense as it lacks the reference to the grades (30° compared to what? ). third using the law extension command once the references are defined. Attachments le.webp 9.9 KB · Views: 6
gioedofabri Guest Mar 31, 2015 #3 Hello, and thank you That's what I wanted to do. I'm fabrizio, torino designer. Thank you.
