silvius
given as output a design of this type:http://digitalschool.ca/wp-content/uploads/2013/11/1detail_drawings_onpressure_vessels.jpgwith which other instruments would you deal with work?
autoplant (bentley or autodesk) or, alternatively, excellent alternative I would say......... He had pdms.given as output a design of this type:http://digitalschool.ca/wp-content/uploads/2013/11/1detail_drawings_onpressure_vessels.jpgwith which other instruments would you deal with work?
I keep seeing 3d design on software and tabled with other software, for finishings, tables, symbols. in autocad you do first and better.. .for the table in question any cad 3d or 2d.
for the design the scope is the piping. so what you have to ask is which cad has the best module dedicated to this specific field? which has bookcases, which can be inserted in the flight "couple using this flange", given a path "use this standard tube and put to flight these elbow fittings on the curves" etc. etc.
It is not only a matter of drawing it, all cads draw it.
and I may also agreesbagliatissimo c3kka...
It's just a question of method.and I may also agree
in theoretical line though.. I said this only because unfortunately I need to be practical and flexible and sometimes the various solidworks and company are not....
I can't waste time "litigare" with autogenerate boms and/or custom properties, I often have to manage various designs of which only a small part is "born" by a 3d parametric. . .
autocad and his "lightness" (at least in his incarnations prior to 2010) is sometimes of great help.
absolutely true.. I'm quoting everything you wrote. .It's just a question of method. .
"oohhh, listen, but how did you get a group to send me that I'm going to buy it...? Are the codes missing??? We're gonna get it from here, so much for now it's just to order the materials, no no no no, it's okay to give it so much, it's preliminary, so in the morning when I get to the office, you make me find everything ready?absolutely true.. I'm quoting everything you wrote. .
I repeat, however, that unfortunately the real dynamics of a medium/small company sometimes do not allow to respect this method... .
I only work for small middle firms so I know the problem. the time you earn with these shortcuts you almost always lose with wear interests after. Sometimes time to make similar items you earn just when, with a neat and managed 3d archive, you can quickly find the most similar object already produced, cloning the components that change and change to the flight. Obviously the updating of the tables is all assisted by the cad, it should not intervene by hand with the risks of errors that follow them.absolutely true.. I'm quoting everything you wrote. .
