tape conveyor: declaration of conformity or incorporation?
hi, buying a conveyor belt with a special accessory, we realize that the supplier redirects the Declaration of incorporation instead of the declaration of conformity , having to resell it as we have received it We would like to know if it is right to receive and then to provide the declaration of incorporation or instead the declaration of conformity.recovering what is reported in the legislation
"The car is a
— together equipped or intended to be equipped with a system of drive other than human or direct animal force, consisting of parts or components, of which at least one mobile, connected solidly for a well determined application,
— together with the first indent, to which only elements of connection are lacking to the site of use or connection to the sources of energy and movement,
— set of the first and second indent, ready to be installed and which can only work after being mounted on a means of transport or installed in a building or in a building,
— sets of machines, of which the first, the second and the third indent, or of almost-machines, referred to in letter g), which in order to achieve the same result are arranged and commanded in order to have a solid functioning,
— set of parts or components, of which at least one mobile, connected solidly and intended for weight lifting and whose only source of energy is the direct human force"
"the quasi-machine is a set that constitutes almost a machine but which alone is not able to guarantee a well-defined application. a drive system is a quasi-machine. "
... I totally disarm myself and redo all to a nice "go to tastes, depends as you see it" :frown: in the sense that at mè these definitions do not define a good nothing, I do not understand the difference ... I ship and find this:
... but a wiper is not really a
for example his electric scooter
certain is mobile: Turn around all the time!
all connected inside a metal casing, with a well determined application: sweeping the glassesso the wiper is a machine No?
because if instead we take for good the reason we say then whatever will have a job that previews to be installed or connected or dependent on other ...
the conveyor belt "transport" but only if connected to the current via an electrical picture and only if it is loaded by something else, means that even the conveyor belt without electrical system is “almost-machine”?
do you have the strength and patience to explain to me the general logic and also to tell me if it is right to receive and then to provide the declaration of incorporation or instead the declaration of conformity for the tape in question?
the discussion is old but as the answer is complex and has generated many "litigi" I wanted to tell you my opinion. after a while I found the answer that satisfied me enough to continue working well.
the answer is not unique (and you will have understood it from the fights... :) and I have understood it (I think) since I decided to really read the directive (first I avoided and wrote on the forums looking for a certain and short answer... ). If you are a car or almost a car depends on how many ress you have respected, if all you are a car to all effects, if you respect a bit you may be a car or a almost machine, but in the end "it is not so important" just do the things done well: you have to inform the installer what ress you have done you what must do him.
I'm certifying a line, I have a frameless tape, the manufacturer has marked it as a machine, what do I tell him to declassify it? no, I read all the ress and I realized that he res 1.2 command systems did not consider it so I consider it as line installer. Sure now I'm "litigando" with the electrician/plc programmer who doesn't want to do his part on this point... But you can't have everything too easy!
