un_poldo
hi, I don't know if it's the right section, my question is addressed to the "norms" of the technical design rather than the use of the software.
I have a sheet, 2 mm hypotheses, which I want to bend to 90°.
in the drawing I want to indicate to make a fold more "to live edge" possible. what would you indicate in the drawing?
do 2 lines at 90° with live edge and put a text caption?
do a minimum radius simulating the best possible result and quote it (if you quote the inside, the outside, or the axis?)?
indicated the use of a specific quarry? (if you have to make the piece, you have no quarry in question? )
