telescopic cylinder
  • Thread starter Thread starter MBT
MBT
Good morning to all
Have any of you ever ventured into the meanders of the telescopic cylinders?
avoiding the contact group (I do not like them much...), how did you do to parade the various elements?
consider that then the cylinder should be substantiated so that it can be used as a flexible assembly in the upper-level axis. . :rolleyes:
thanks to all for suggestions :smile:
Good morning master,
you could try using the "movement" window inside "modification bond".
insert the max race that can make the component and the game is made.
p.s: I have never tried this command on the telescopic cylinders.
right, they will be bound to "fall" or constraints to 2 to 2 the various cylinders with the relative races of max and min.
the problem is if you want to animate.... inventor does not know what will be the cylinder opening sequence
Master buongiorno,
Great calm.. .
There was only one master! :finger:
At the most I can boast of being his humble servant:redface:
mumble mumble. .
I think it's one of the delicacies of the new versions
I still use 2009... :frown:
any other suggestion that works with "antique" versions?? ?
mumble mumble. .
I honestly don't remember if there were previous realases, even because I never used much inventor, but do you have the chance with 2009 to put limits on constraints?
I also used 2009 and I remember that there was a command where you could set the maximum race.
otherwise I think they touch your beloved "contacts!....=)
@peppe:
I don't have the pallidest idea for animation, I think that happens as you say.
Reviewed::frown:
or spend to upgrade, or use the contact group, which is equivalent to pulling the bricks on the [Bleep]:biggrin:
not that I am, in fact I asked opening a special discussionhttp://www.cad3d.it/forum1/showthread.php?t=25251
Maybe there was.. .
I have in fact opened a discussion about it.
Reviewed::frown:
Sob...
I would also spend, but the company says to wait and pass directly to 2012 (we hope not on the occasion of 21 December... :rolleyes: )
