temporary phase problem
  • Thread starter Thread starter dakky
dakky
Good morning I have a problem and I can't figure out how to solve it.
then I have a design with three stages:
state of fact
red and yellow
project status
This project, however, refers to a project older than another professional where he had approved works but which were not then realized.
if I put an element realized and demolished in red and yellow (to make it blue) then I will not see it in the state of fact.
How can I do to have yellow and blue reds correct in the same table?
because I can do another phase before separating the state of the places and what was fired, but I would like that red, yellow and blue were all in the same table. Thank you in advance
you make confusion between phases and phase filter! :4404:
red and yellow is not a phase!!! !
provided that red and yellow are not a phase, but a phase representation filter.
to do as you say, you can use the "temporaneo", that is objects/families built and demolished in the same time phase (so to draw and demolish in the project state)
if you check the phase filter also the representation of the temporary (replaced) you will have the representation, in the same view with red, yellow, and blue.
see also this discussion:http://www.cad3d.it/forum1/showthread.php?t=26668&highlight=fasi
