text frame in multidirectors
  • Thread starter Thread starter ilbona
ilbona
I created a multidirector style, which plans to frame the text. the problem is that the frame is sticking to the text and I can't in any way leave a greater space all around. Does anyone know the solution to this problem? I think it's a problem many have, but I haven't found arguments in the forum.
There is no solution.
Perhaps, however, with the creation of a custom dynamic block you could overcome the problem, but it is to be evaluated.
the dynamic block would replace the textm as a type of multidirector.
But never tried to use dynamic blocks for multi-directors, so I don't know if they would work as well.
you can change the buffer around the text (with or without frame) by changing
in the "contained" tab the value of "connect line space"
the distance of the text from the link line, and the frame is not affected by that distance.
In fact... the frame is "attached" to the connection line, increasing the distance from the line to the text also increases the buffer.
Sorry, what version?
I am on a pc with 2011, I checked and the buffer does not increase!!! :confused:
