text on curve
  • Thread starter Thread starter Ghirarduzzi.G
Ghirarduzzi.G
I would like to introduce the stamp of the order of engineers into the table, which I attach to you in the image (in part purified of my facts :36_1_12:).
I have already "resolved" with the image only that clearly being an image and not a vector format clearly deforms when there are variations in size.
Moreover (and this is the most serious thing), it goes to know why, in order to get the correct size of the image in print I have to maintain size definitely greater than the image itself in the cartiglio, which also happens while I am making the table, and this is quite annoying because in practice I do not have the entire graphic area available.
so I would like to know how I can do to make " sketch" the stamp. Of course the only things I still can't do are the two circular writings that stand along the edge of the stamp. a circle, a line and a couple of writings are still able to make them! :36_1_11:
I thank you in advance and wait for news.
inside the sketch you find the command to write tests that also allows you to place it along a curve.
to create a symbol with a logo I usually model it in 3d, put it on the table and create a symbol by copying it.
Bye.
Ooops!
Sorry. .
hello max! here all right...
as you predicted the good b. still drowns in the assali/ponti speech.
but his problem is that too much of "old mold". he thinks that the other day spent 2 hours (but not to say an exaggeration... of watch!) trying to convince us that from the company's headline for a document to be sent to the ministry, we had to remove the written "smart machines" under the name of the company in the logo because otherwise there was no coincidence between our name accredited to the ministry and the logo.
called the homologation advisor... He spoke to his old colleague from another company... He did everything!
Fortunately at the end the owner intervened (that for that logo he paid several quattrini) and said that the header was fine.
Good idea!
If you have time, would you like to give me some more details?
especially with regard to the writing along the curve and the creation of the symbol.
thanx (is slang eh... before someone tells me that you write thanks) in advance!
hi gianfranco, look at the annex.
when in the sketch activates the text command, you open a window as from attached image.
activate the "long curve neck" option and select the curve along which you want to realize the text.
Okay, guys!
and now that I created this fantastic extruded... :36_1_13: what do I do? :36_1_5:
put it on the table, put it in dwg or dxf and then create a symbol that you can use for the paper mill or for what you want.
It is much better than using bitmap images, for quality and lightness.
Max,
I'm sorry if I bother you, but since we're a few steps away from the destination, I'm asking you for help without dropping in the forum.
I created both the dxf and the dwg. two problems.
  1. clearly in the table puts me only the contour of the part and therefore only the contour of the letters that instead would go "full".
  2. How do I create the symbol? because when I re-open the newly created files, I re-open a drw and so I'm point and head as if I didn't create the table.
