joe Guest Sep 16, 2009 #1 I would like to know politely because the text printed with "hidden" option is always empty, even if the textfill variable is set to 0
Shape Guest Sep 16, 2009 #2 joe said: I would like to know politely because the text printed with "hidden" option is always empty, even if the textfill variable is set to 0 Click to expand... It is normal to do so, with the option "hidden" objects empty nnon have solid filling, if you see in the example the text behaves like a region or a cube (full of course). If you do not want emptying, you must avoid using characters with filling. Attachments untitled.webp 15.6 KB · Views: 3
