text symbol
  • Thread starter Thread starter MaiMollare
MaiMollare
Hello everyone
I would like to integrate the text symbols table with a new symbol, explain better: inside the text symbols table there is the st symbol (statistical tolerance) inside a rhombus pitch, to me I get the same symbol with the letters cf (continuous feature). until now I have created a design symbol and I have inserted it every time in the quota that interests me.:angry::angry:
I wondered then if it was possible to insert it as text from table text symbols.
Thank you very much
hi maimollare,
would you tell me how to change the thickness of the section boards? ?
But my question?
However if it can help you have to change the thickness of the pentable.pnt print pens, in this way on the printed table you will find the axes of the thickness you set. It's something I never did because my file was preset by others and you can't change, so I don't know how you can open and edit .pnt files
hi maimollare,
But then did you manage? because I am also in the same situation:frown:.
Thanks for a match! ! !
disability
hi diego
Unfortunately, I am not continuing the old way and seeing the hemorrhage of answers I received I do not think it is possible. I have also been informed by other sources but it seems that no one has solved this problem.
Hi:36_6_6::36_6_6:
on the ptc site, in the resource center under reference documentation or also on the pro-e online guide you can find the pdf installation guide and administration.
in this document related to the wildfire 5.0 (and not in the old versions) is explained (page b-25) how to manage and customize text characters and symbols.
the pdf I attach it to you.
Bye.
I thank you for the suggestion, I swear I tried but I get really complicated instructions to follow.:36_6_4:I can't figure out how to compile a new special.src file and how to make compile_font.exe work and other things again. :36_6_1: I believe that for these arguments a small course or a higher comprehensibility manual (or a less pumpkin than me).
things I can't have via the internet.:36_1_4:
I created a symbol and used it when necessary, thanks anyway
