text under line quota
  • Thread starter Thread starter Gabriello
Gabriello
Good morning to all,
can you insert the text under the quota line directly from the quota command?
thank you all for the kind answer.
ciao, domanda ambigua. the value of the quota below the line or add a text under the line ?
cation
open the property tab (which I recommend always keeping open ), text card, last row __ edit local text then type <> space \x space then the text, if it is too long or you want to make multiple rows then to head type \p between words.
Excuse me, but are we talking about autocad or inventor? in inventor you can create a text style from the default in which in the "text" tab you select the icon that allows you to place the quota text above and below.
Hello zac69,
I'm talking about inventor, but the button you say I can't find...
select the share you want to change > new quota style. opens a window where you can give a new name to the style (e.g. poplar). then select the pippo style and go to the tab "text". a dx where there is orientation, you can decide how the text will be inserted compared to the line. Save. at this point to the two styles, one normal and one you can use when you want double text.
you have to go as in the image, click on it and select the text on horseback of the quota line
Well, remember that this style only applies to this table.
if you want to do the same on other tables or do the same procedure or save the style created in the style library.
