presariog
what function should you activate to write text on a part without needing to extrude but only as written .... without triggering the decal?
something wrong, because if you use the "wrap" function with the "trace" option, the faces that you can then color and are not visible on the opposite side.Okay.
do a sketch with a text on a floor
select the sketch use the winding function and selecting the plan on which the writing and the superfice target curve lies but, the projected writing is also seen in transparency unfortunately. I did the projection on a full round but I also see it on the opposite side! ! ! !
the phrase so no one needs.unfortunately I can't open the file
