texture su material problem
  • Thread starter Thread starter D4n13l
D4n13l
Hello everyone
I have a problem with creo with textures, I am trying to create a material in which inside there is a texture to be applied every time imputo to the 3d the material, when I create it except the appearance of the material with the new name to which I applied the texture that is in a path of the company network, except the material and so far all right.
at the moment when I reopen I create and impute to the part the material in which I had previously applied the texture, this appears white.
in the config.pro I added the values save_texture_with_model on yes and the texture_search_part in the network path where the textures are, but without great successes, when I go to open the material aspect editor and I go to apply the texture the first folder that I propose is in this path c:\ptcreo 4.0\m090\common filesgraphic\-library\textures\
Can anyone help me please?
I am almost 100% sure that these are search paths that overlap, check in the config in the program installation directory.
Careful that every time you install a new "m" release, you reinstall the entire program, then also a new internal config.
solved the problem with ptc assistance, it was a global.dtm pointing problem
