the bitch of a tubo
  • Thread starter Thread starter folle76
folle76
Hello.
I looked for something, but I found only general information. my question is very precise, although theoretical because I have no experience of curved machines (I ask the question for interposed person). Suppose I must bend the attached pipe and I am the operator to the machine.
from point 1 to point 2 I run the pipe.
at point 2 I must turn the tube of 7.9° and then I must bend it of an angle of 42.3°. angle but I only fall from 3d. and then I have to move on to point 3 of a length that I echo from 3d.
I saw that it is possible to generate .isogen files. is that you can get a file of this type with three columns?
bending rotation length
thank you for any info you can provide me.
I don't think of anything automatic without the piping module.
let's see if any user in possession of the above form is able to give you an answer.
yes it is possible but to generate isogen files it is necessary to have the piping module.
hi mad76, as for your request they have already answered you.
consider that to the operator that must program the curvetubi, a table with the x,y,z coordinates of the individual points is sufficient.
will then take care of the cnc of the curvetubi carry out the transformation from Cartesian coordinates to polar coordinates.
by experience, it is also useful to provide the theoretical development of the pipe so as to perform the cut from bar (and in this case, even without the piping module, you create a matrix of x,y,z points for which you will pass a curved datum with the desired bending radius (constant).
If I wasn't clear, ask.
