davide&golia
Good morning to all,
I wanted to ask you a question to which I did not find answer in any corner of the web.
I hope therefore that someone of you, with certainly more experience than me in the field, can give me a hand or at least direct me to a path.
in die casting machines, how do they make the seal inside the injection chamber to avoid aluminum piping between the piston and the cylinder?
I thought of two solutions:
In the second hypothesis, I think the problem can be the aggressiveness of aluminium at the above temperature, which would lead to a quick wear of the bands.
I hope someone can give me an opinion on this problem.
cordial greetings,
Davide matvelli.
- realize a coupling with interference between piston and cylinder;
- apply seal bands similar to those for internal combustion engines.
cordial greetings,
Davide matvelli.
