the nx7.5.2
  • Thread starter Thread starter The_Matrix
The_Matrix
Hello, everyone.
is available for download nx7.5.2.. .
may be the 2011 block point version of fga/cga.
contains many interesting things especially for those who do routing and cae, moreover, for the "fans" of the 2d has the possibility to make "independent" a view of detail.
... and do not forget the great novelty of 7.5.1: :cool:mechatronics concept designer is an application that you use to simulate the complex motion of mechanical systems interactively. it is designed to support the early machine design phase that provides the basic machine concept including the mechanical, electrical, fluid, and software aspects. it is a solution that transforms the machine creation process into an efficient mechatronics design approach.
this application is built on the following principals:
functional machine design
one of the main instruments in this is the functional model, which forms the foundation to provide an interdisciplinary view of the mechatronics system machine. it lets you lay the foundation for collaboration in detailed design by supporting the early design phase with a functional design approach.
the functional model provides the link between the data management of the different disciplines and the requirements. this enables the traceability of the customer demand data down to the design departments. further, the functional model provides a supporting structure to come up with initial design concepts and has the features to perform an evaluation of design alternatives.
early system validation
mechatronics concept designer introduces a verification technology that is built on a new simulation engine. it helps validate concept designs at a very early stage of the development process.
multidisciplinary support
mechatronics concept designer facilitates interdisciplinary concept design up front. the following disciplines can jointly work on a project:
mechanical engineer creates the design based on 3d shapes and kinematics.
electrical engineer help select and position sensors and actuators.
automation programmer designs the basic logical behavior of the machine. he starts with time based behavior and then defines the event based control.
modularity and reuse
mechatronics concept designer provides the ability to capture knowledge in components and store them in a library to enable the reuse of this knowledge in other projects. since the library components are based on already proven concepts, it improves the design quality and speeds up development.
mechatronics concept designer supports the definition of functional units such as those in the vdw standard funktionsbeschreibung.
s o f t w a r e sfb-nx-5686
f i e l d page 1 of 1
b u l l e t i n issue date: nov 8, 2010
revision date: n/a
supersedes: n/a
submitted by: ben broad
responsible group: nx cad app
gtac 800 # options(s): 2-1
subject: maintenance release nx 7.5.2 is now available
affected software: nx 7.5
associated pr number(s): n/a
scope: windows xp 32 & 64-bit, linux 64-bit, mac os
revision: n/a
dear siemens plm customer,
we are pleased to inform you that maintenance release nx 7.5.2 is now available for download from the siemens plm ftp server. nx 7.5.2 is an accumulation of fixes built for installation on top of windows xp 32-bit, windows xp 64-bit, linux 64-bit and mac os images of nx 7.5.0. please note that maintenance release nx 7.5.2 will only be shipped (on dvd) by request.
select the following link to download this maintenance release or to review the readme. note: a valid webkey account is required.
windows xp 32-bit & 64-bit:
http://ftp.ugs.com/unigraphics/maintenance-release/nx75/winxp/64-bit linux:
http://ftp.ugs.com/unigraphics/maintenance-release/nx75/linux64/mac os:
http://ftp.ugs.com/unigraphics/maintenance-release/nx75/macos/
please refer to the readme file for maintenance release installation instructions.
sincerely,
siemens product lifecycle management software inc.
industry sector
what you mean by block point 2011 of fga/cga.
Forgive me but the English are more and more hostical
Excuse me. .
block point = moment when you change the software release
fga = fiat group autoes
cga = chrysler group automobiles
... is not yet said... may also be the nx7.5.3 that will contain some interesting things on the parametric modeling part.
Hello.
you know what is the current version nx used by fga /cga and when they want to change releases?
excuse grammatical errors, but I don't have to write in Italian.
Hello.
Well, if I wrote the German as you wrote in Italian...
My compliments
for the answer to your question I think you know more about matrix and you will certainly not be able to answer
Hello.
currently:
nx 5.0.5.3 mp4
tc 2007.1.8.4
is in preview the block point at the end of June 2011:
nx 7.5.3
TABLE 8.3.1.1
... say, at the current state of testing...
If there are any problems, there will be hot fixes or mp...
