the printing of the table does not correspond to the preview
  • Thread starter Thread starter skia51
skia51
hello to all
I searched in the forum but did not find the solution to my problem.
with solidworks 2018 I had set, for the table, various characteristics and colors of the lines, and in the printing phase, this was equal to the preview.
now with solid 2020 all lines have the same color and the same thickness, sometimes the odds confuse with geometry.
Yet the preview shows me the lines with correct colors and thicknesses, the problem only happens in direct printing from solidworks, because if except pdf and then mold the file, everything is printed correctly.
Are there any settings I need to change? Is it a driver problem?
thanks to those who will help me
the lines are found on various levels, each has activated the print optionstampa.webp
Good morning,
I don't mold much, but I remember that this button gave me problems, maybe you selected it.
Hello simonecrv
Thanks for the answer.
I checked, but that command isn't selected.
When I select it, I see all the black lines at video, but nothing changes in the print.
I did a further test, if except the table as pdf, all the lines remain colors that I assigned them, instead if mold using the virtual printer "microsoft print to pdf" the file that saves me is like the printed one, or with all the black lines.
beginning to think it is a problem of windows, perhaps generic printer drivers do not manage the colors of solidworks.
I will make further evidence
solved! !
It was easier than I thought.
I found this word in the guidecolore.webpand I checked, in fact if in the print settings I use the "automatic" command the printer does not recognize the colors
I need to use gray color/scale command
in this case the print reflects the preview.
thanks and good work to all
