pietro2014
Good morning to all,
I have to make a tin oven having two 1500w electric resistors available from dia.16mm that I will insert inside a 160mm wide plate and 70mm thick.
I must therefore heat the plate up to reach 220°c mainly under the two channels where there will be pond to be brought to the liquid state.
I would like to understand if the c40 material with the geometry and the temperature in play is usable.
