gil
are to ask you advice to improve the thermal insulation of an existing house.
the house has walls built with furnaces (comuni brick perforated); last summer the roof insulation was realized with ironing plates and walls with expanded polystyrene and then plastered.
now it is thought to eliminate the inner lining in plasterboard.
Do you think it is appropriate to replace plasterboard with other material, or the 30 cm wall + 3 cm of polystyrene/stirodur are enough already?
