mgdi
Hi, I've got a little... analysis.
I have the axieme, of which I attach an image, assembled as a mechanism and working.
the principle and the following:
- the disc is solid with cam b and rotate continuously at constant speed
- the cam makes to the bracket c a movement "painting" not constant so that for a certain angle the axis a1 follows the axis a2, then returns to the starting point and follows the second axis a2 of the series of 3 then the third and so on.
the analysis I would like to do is to be able to verify that for the angle actually established the axis a1 follows a2 . I would like to get the angle position of the two axes during the simulation of the movement and compare them graphically or testally.
I tried different analyses (even by associating a point for each axis) but I couldn't get what I was looking for.
do you have any suggestions for me? Thank you.
